Re: Single cylinder overhaul cost.....112hp johnson
I have seen prices posted here from $2-400 per hole assuming you do it yourself. You get a marine engine shop to bore the hole & provide the piston. The rest is gaskets, sealers & stuff. <br /><br />It is an absolute must, if you have never done3 it before, to buy the OMC shop & parts manual for your specific motor. There is nothing high tech about the job. You need a clean work environment, average tools, patience, time - another must is to determine what caused the original problem or face the possibility that it may reaccur.
