lifes great
- Jan 20, 2004
- 75
Does anyone know a simple way of testing this generator? None of my books have the resistance readings. I opened it up and cleaned up the brushes and tested the windings, all appear ok. When its hooked up and the engine is running (idle) and I touch the (F) field to the hot side of battery with an amp meter it looks like its about 4 amps. However Im not sure if its a discharge or charge of 4 amps. With the engine off it will show it also. I also bought a new regulator (vr203) and when I run it through it I get nothing at all. I tried all different (rpms) but nothing. Question is it possible that the battery is fully charged (new) that it wont allow the regulator to kick in? All connections were good and a good ground. Thanks.
