1984 Johnson 115 V4 (J115TLCRD). I've been rebuilding the engine piece by piece (yes, I know it's not economical). I originally thought I was only going to have to bore to 040 or 044, but it had to go to 064 to clean up properly (and I would have just trashed the block, but I can't find a good replacement to save my life). I was planning on changing ALL jets based on the 044, but now I'm not sure what I should jet to for the 064. Everything is stock to the 115 except for bypassing the VRO and using an '83 fuel pump.
