Re: 9.9 hp 4 stroke power pack
Is this the same thing that happened the other times too?<br /><br />Have you ever had anyone else service the engine or troubleshoot this problem? I have seen on more than one occassion, where someone else had attempted to repair one of these motors and the complaint was similar, pack after pack after pack... In reality though, the first pack probably was bad, but during the troubleshooting process, when they tested the charge coil and power coil outputs, they had distorted the packard connector terminals and this caused an intermittent electrical connection to the pack.<br /><br />Disconnect the plug in connector at the pack, and look at the blade (pins) inside the pack - they're flat and very narrow. Now look at the connector - are the sockets similarly shaped or do they appear rounded out and distorted as if someone forced a volt-meter test lead into it?<br /><br />Also, did you eliminate the stop circuit? Or test the charge coil and power coil? Either of these 3 items could also cause a no spark situation.<br /><br />-John
