ga_sportsman
- Feb 27, 2015
- 10
2003 Johnson 70hp Outboard - Model J70PL4STC - Power Trim/Tilt Goes Up But Not Down
Power Trim/Tilt works normally going up, but will not come back down. Operating the trim down switch (from the helm or the motor itself) you can hear a "click" sound but the pump motor doesn't run like it does when going up. The only way to get the motor down is to manually release. Fluid level is good. Can anyone offer suggestions on what could be the issue?
