StriperChaser
- Sep 29, 2001
- 79
My 1996 Johnson 112 SPL randomly stops running while under power running down the lake. It starts right up and runs great every time out but randomly will just completely die then starts right back up. I'm positive it's not a fuel problem because it goes from running smoothly to completely dead. The only way I can duplicate the problem is to turn the switch off and on while under way. It's never left me stranded but its a problem I have been chasing for several years now. Some times I can go all season without a problem then randomly happens again, I have gone through the entire electrical system cleaning and tightening connections. I thought I had found the problem in a large wiring harness connector under the console that was corroded. But the problem has come back. It happens so randomly a boat repair shop may have to run it for hours to duplicate the problem if it would even happen at all. Any suggestions would be greatly appreciated.
