I have a problem with my 98 225hp Evinrude with the starter not engaging. Here is the scenico,boat started great,ran about 10 mile out,shut of engine,went to start engine about 15 min later,nothing at all. I have checked the fuse to the engine,looked at the pins in the harness,jumped out the netural safety switch. I have disconnect the main harness,jumped the soleniod,starts right up.plug harness back in ,dies out. I replaced the ingnetion switch,looked for loose wire in pin connecters. I was thinking bad soleniod,thats the only thing i can come up with. Any ideals to fix this problem?Forgot to metion both batteries have a full charge.Also the engine goes thru the sytem check check,but no ignition.
