Hi;
I have a 150hp Johnson outboard from 2003 and suddenly its tachometer stopped working. A mechanic told me that voltage rectifier/regulator should be the problem. So I replaced it with a new one but issue persist. Tachometer was not working. I also replace the gauge with a new one... same results. :blue:. Current gauge include the tachometer and also the check engine system lights (hot, no oil, etc...)
Any idea of what could be the problem?
Any suggestion is appreciate.
