Cricket Too
- May 14, 2003
- 1,732
Renaming this post, beacuse nobody seems to be responding to the previous one that I opened, except OBJ, and I need a quick answer. OBJ told me how to locate the recirc valves by following the lines back to the intake, but I need to know how to identify the lines. Would they be the 3 lines running to the port side of the motor at the intake? It looks like there are 3 lines running to the intake with a small fitting at the end going into intake, is this the valve? It seems like it is considering there is 3, one for each crank bearing, is this correct? Refer to post," PM on Johnson 200", thanks in advance.
