fuel pump info that may save someone from a headache
jcr0340
Hello all. I'm am posting about a fuel pump kit Pt# 18-7820. This part is supposed to fit 1970-1978 75 HP Evinrudes. It does not. This kit is sold by many different dealers including some auto parts stores The kit is also sold for numerous other evinrude years and sizes which it may fit. What I do know is no mater where you buy it, it will not fit 1970-1978 75 hp. Just want to help maybe some one else. jerry fuel pump kit.PNG
Why did it not fit / work on your motor.---Any pictures of your motor and pump ?
gm280
Is there a any possibility that somebody else changed the fuel pump on your engine over the years to another that fit? Because an obvious error like you are referencing surely would have been noticed before this...
F_R
I just checked, and the kit should fit the 1970-78 3cylinder models such as your 75hp. So...either the pump has been replaced on your motor, or the kit is mis-packaged or mis-labeled.
achris
More fish than mountain goat
Probably got a 90hp pump on it because some 'clever' person thought a bigger fuel pump would push more fuel into the engine make it go faster... :facepalm:
robertd338
complete fuel pump assy. part #: 438559 (BRP.) repair kit # 393103 (BRP) sierra # 18-7820
bob johnson
it would be nice if jerry told us the part # on HIS fuel pump...then wed know where the problem might lie.
bob
