So I'm kind of of new to the world of small outboards, and boating in general. I own a small 5hp seaking, and that has it's own gas tank attached. When I bought the motor I made sure the lower unit wasn't seized just by seeing if the propeller moved around. I had the guy start the engine and checked to see if there was adequate water flow, since it's water cooled. I got the thing real cheap so as long as it worked I didn't really go into it further then that.
At this point I'm looking to upgrade to this 9.9hp johnson. The guy wants $150 for it, and I'm supposed to go look at it this week.
This engine is a little more complicated then what I've dealt with before with the seaking. For one I'll need a separate gas tank for a motor this size right? From the picture it looks like there isn't a gas tank on the actual motor. . . How does that work exactly? From what I've seen in youtube videos you have to "prime the bulb" to get gas flow from the tank to the engine right? I've seen gas tanks for these size outboards being sold on CL. . .
It might be reasonable to consider the possibility that I might not be able to actually see the engine run before purchasing this outboard before buying like I've been able to ask for with smaller outboards. In that case how can I be sure that I'm buying something that's in good condition or at least is in running order?
Of course the engine needs to be in a barrel with water to run safely, but is there anyway I could hit the carb with starting fluid to see that the engine turns over and the lower unit works? I only need to see it run for a few seconds.
I can deal with carb issues. My seaking has some carb issues, all I have to do is hit it with starting fluid before I head out for the day and it's fine. Starts up easily enough when its warm
Obviously I'm kind of lacking on knowledge in the small outboard department. I know some really basic info but that's it. . . can anyone point me towards any resources so I'll know what I'm supposed to look for when purchasing outboards in the future?
Thanks!
Thanks!
