crankbait cowboy
- Mar 25, 2013
- 570
trying to remove just the outer exhaust housing to get in and inspect the dual water tubes. the lower unit ( gearcase) is removed and i have removed the 5 main bolts connecting outer housing to adapter and the stern bracket bolts. what am i missing as will not budge. do i need to remove the power head to get at more bolts on front end, or what may i be doing wrong or missing. i only want to remove the outer housing. any help or suggestions greatly appreciated and thanks
