Hello,
I posted a topic a couple of days ago related to the points, which i have since resolved. I realized that i had a few related issues, and it would make more sense to keep it in one topic.
Here is the rundown:
I inherited an old engine(sound familiar?) a year ago. I went about looking through it, and did the typical carb rebuild, etc. The 1959 didn't have a fuel pump, so i first tried the fuel pump technique using a cap on one of the check valves. I was discouraged from going this route, so found a bypass cover with the nipple for the fuel pump, as well as a 1960 fuel pump. The pump looked pretty good, i replaced all the gaskets on it and hooked it up. I covered the nipple that goes to the intake manifold with some gasket sealer and a pump cap to temporarily seal it.
Today, after getting the ignition system sorted out, i hooked up a portable tank and tried to start the engine. I was having trouble getting the fuel bulb below the carb to fill up. Gas was leaking from the tank hose connector while only a little bit flowing into the fuel bowl. I disconnected the hose from the carb and fuel flowed pretty easily, so i am assuming the fuel pump is at least somewhat functional, or at least not impeding the flow to the glass bowl.
I took the carb and manifold back off, cleaned them up again(compressed air, etc) and reattached, but i'm still having trouble getting the fuel bowl to fill up. Carb looks good and the reed plates and intake valves are in good shape. I put back the check valves after trying to other fuel pump experiement
I guess my first question would be: If i'm able to get fuel out of the hose to the carb, but not into the carb when attached, is there something in the carb/manifold area that would be suspect? How can i bypass fuel pump for now to try to turn it over?
Thanks
Ian
Thanks
Ian
