supergoose
- Aug 24, 2003
- 4
The trim motor works fine, you can hear it going. The seals I think are bad. You can raise the motor with the assistance of some lifting while using the switch, but then the motor just goes right back down again, and rests against the rams. If boat is underway, then rams go in and motor is at full trim, and cannot lift while running. I think that htere isn't any pressure in the system. Mechanic says that I cannot get new seals and need whole new trim out fit. Yet everything works fine, just seems to be that seals are worn out. Is it hard to change out the seals. I need help badly. I think that the mechanic is lying to me to get more money, he seems shady. Thanks to anyone that can help. Supergoose
