Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Thrust Washer
  • Thrust Washer
    Trying to replace the prop on my Johnson 225 (1993). Got the prop off, but can seem to budge the thrust washer. Any hints on getting the washer off? I'm kind of leary of trying to force it off and possibly tweaking the shaft.ThanksEd
    Re: Thrust Washer
    Ed, give Mike Clark at Clarks marine a call. His shop is behind Fishermans hardware now. Nicest mechanic i've ever met, he's helped me out a bunch of times and isn't rude like other mechanics in this area. No affiliation, just a happy customer, I have a 12 foot boat and its rough to spend $60 an hour on small problems.......Good luck...Warren
    • #3
      Re: Thrust Washer
      hello well most stick. yammi's and mercs stick as well. I take a hammer and give it a sharp rap on the face of the thrust washer. the washer is stuck to the taper on the prop shaft. good luck and keep posting
      no tech questions by PM, they wont get answered.
      you have to be trusted by the people that you lie to .
