Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
pressure test lower unit
This topic is closed.
  • pressure test lower unit
    how do they do this test? & where do i find the specs on how much pressure a particular gear case is supposed to hold? i have a radiator pressure tester & could adapt it would that work?
    Re: pressure test lower unit
    This is how I do it.I drain the oil out of the unit and remove it from the the outboard.I attach an airhose with a pressure gauge to the oil inlet of the lower unit and pressurize to about 10 psi.Now i dump the whole thing in a barrel of water and look for air bubbles.You leave it in the water for a few minutes to make sure there are no hidden leaks.And that is it!Do not put more than 10 or maybe 15 pounds of pressure on, because you will blow the seals.
    Make sure the plug is in
    • #3
      A good gearcase should still have some pressure after 45 minutes. If not, start looking for leak(s). OMC manuals explain this in detail. There's no need to remove the LU unless you determine there's a leak.
      Jim
      I don't respond to Private Messages PM's that are motor questions.
      For basic information on a wide range of topics, see Top Secret File
      Link: http://forums.iboats.com/showthread.php?t=299680
      OEM shop manual: outboardbooks.com or Ebay
      • #4
        How old is your engine, some of the little, or older engines with single seals don't seal all to well. I have run into some gearcases along this line that will a have a groove worn into the drive shaft at the seal, these will hold static pressure, but have some seepage with the engine running.
        • #5
          how about if i change the fitting on a radiator tester i have & pump it up to 10 psi. & then wait to see if i have any bleed down? do i have to put it underwater? do i have to drain fluid?
          • #6
            When vacuum or pressure testing a LU:1] drain the gear oil (it will mask results otherwise)2] apply vac or pressure (15 psig max)3] wait 30 to 45 minutes, should have some press or vac remaining. No need to put under water unless leakdown fails.4] done
            Jim
            • #7
              It's best to pressure test at two different settings according to the factory service manual. First check at 6 psi, then at 15 psi. That way both the orings and the seals are "stressed".
              • #8
                from 15 psi how much leak down is acceptable over 30 minutes?
                • #9
                  I had a carb pop-off gauge that happened to fit the fill tube for my lower unit pump. I pumped it up to about 15psi and it appeared to hold for well over an hour. I'm guessing that means my seals are good? Reason I ask is i was sure I had some water in there when I checked at the lake.
                  • #10
                    I rotate the prop shaft and drive shaft, shift the lower unit while it is under pressure. Sometimes moving a shaft will show a leak.
                    Silly me, I just noticed how old this thread is, I bet the poster has found his problem by now.
                    • #11
                      I'd certainly hope so! Lol!
                      People should learn how to start new threads, don't you think?
                      • #12
                        I bought a boat with a cracked lower unit, took it apart myself and had it repaired. I also replaced exposed gasket, seals, and O-rings. Do I still need to have the lower unit pressure and vacuum tested??
                        • #13
                          hisgirl_81
                          Yes, very old thread and now closed.
                          BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
                          Please, no PM's (Private Messages) regarding boat/engine problems.
                          That is what the forums are for.
                          Only forum/moderator issues will be answered in PM's.
