1969 Johnson 55 HP (55ESL69A)
My manual and everything I've read says these motors should fail in forward but that doesn't seem to be the case here. The shift switch in the remote tests fine. I have correct voltage at the green and blue wires in forward, neutral, and reverse at the knife connectors that go down to the solenoids. When the motor is off, the prop seems to be in gear. As soon as the motor starts, the prop spins freely and will not engage forward or reverse. Even jumping 12V directly to the blue and green solenoid wires does not get the gearcase in gear, yet when shutting off the motor, spinning the prop spins the flywheel. Any thoughts? Next step is tearing into the gearcase, but I'd sure like to know I'm on the right track before doing that. Thanks for any insight!
