Gary R Brown
- Dec 8, 2014
- 3
I have removed the 5 bolts that attach the gearcase to the exhaust housing. I removed the lower screw from the shift connector. The gearcase separated about an inch. However it will not come loose. I`m thinking the shift connector is still holding the unit from coming out, it goes into reverse when I jar downward on the gear case. I don`t want to force it being that I may break something. Anyone have a tip for this
