Hi guys-
Ill try to keep this as concise as possible to try to keep it easy.
Bought a boat with a 1972 65hp hydroelectric shift. Reverse was OUT on the boat. It was out MECHANICALLY and has nothing to do with a hydro electric shift problem. It tries to shift into reverse but grinds b/c the gear is tore up. I used the boat with forward and neutral only for 6 months and it worked perfectly.
Four month ago I came across a new/used lower unit. Changed to the new lower unit and it worked perfectly in all regards (forward, reverse, and neutral) for the last four months...maybe 10 days out.
Two days ago went out and had forward and reverse only. No neutral. Went to check the fluid (it was type C) and it was totally milky and CRAP. I know I should have been checking it better but that doesn't matter now. I changed the fluid to new Type C and I still can't get it to shift into neutral. Have forward and reverse only.
Questions:
1) Would running the bad fluid have cause this (obviously it did) but what happened do we think? I assumed putting new fluid in would allow it to start shifting again but no dice.
2) How hard of a job would it be to tear into both lower units and put the reverse gear from the new/used unit into my original unit that clearly has a stripped reverse gear but shifts great?
ANY more info you need let me know. Crabbing seaon is still open so I'm anxious to get her back on the water.
Ps..I checked the voltage at the green and blue wires and it seems to be what is should be.
Questions:
