My 89 Johnson V6 (150 hp) is only firing on two cylinders. I suspect the power pack but can not get any resistance off the sensor coils. The charge <br />coils read 868 & 871. The Seloc manual that I have states that all V6's have two power packs, but I only have one. The power pack is a 113-3865 <br />and the stator R583853. I am checking the sensor coil from D to A then D-B,D-C. I show no shorts to grd. but zero Ohms between the leads.<br /> Please Help - I NEED to go fishing. <br /><br />Thanks<br />Dan
