Droll
- Jul 30, 2003
- 514
I am looking for some oil for my old Johnson , but it is hard to find .<br />Are the other manufacturers that does make compatible oil ?<br />"Type b" compatible oil is easy to find <br /><br />Found this one at Pennzoil<br /> PENNZOIL MARINE® OUTBOARD GEAR LUBE may be used in all outboard gear cases where an SAE 80W-90 API<br />GL-4 gear lubricant or older Type C is specified. #4947 <br /><br />Are there others ?<br /><br />After searching this forum I found many advices but ....<br />The Omc "Type C" are now replaced by OMC Premium Blend .<br />It is a 80w oil<br />Can be replaced by ATF oil ?? (have heard this one from an local mecanic too )<br /><br />Got the lower unit separated into pieces ,got new seals + gaskets + o-rings + new hub/spring (forward) + new electric wire ,just wanted the correct oil before reassembling .
