out 2 launch
- Dec 11, 2008
- 77
Originally posted by racerone View Post
Any chance the nieghbors pet mice built a nest in the exhaust housing ???
I think racerone may be on to something that should be considered. I have experienced similar problems with outboards though not of this size (140 hp). My experience involved 25-40 hp outboards and is even more common with smaller two strokes such as chain saws and trimmers. Synopsis: Motor lacks power at increased throttle but starts and idles fine. The power loss is smooth without any noticeable miss or surging. Compression, ignition and fuel delivery all check out OK. What I have found when all else seems to check out ok and something still is amiss check the exhaust system for obstruction. I have found that where the inner exhaust housing meets the adapter plate most commonly at its narrowest area or at its sharpest bend carbon will accumulate and start to build up. This in turn restricts exhaust flow resulting in power loss. Just a possibility.
