ohmydog
- Oct 28, 2014
- 44
Today was an exciting day for this new yet reluctant outboard owner/mechanic. After getting much help from you folks here on the forums I was able to fire up the motor briefly today. It was a glorious few seconds before I noticed that it wasn't pumping any water through to cool it, so I shut her down quick. Obviously the next step was to remove the lower unit and check the waterpump. Which I was able to do relatively easy considering my green horn status of ob mechanical knowledge.
Upon inspection I found some pretty ridiculous stuff and some kind of troubling things as well.
1. When I removed the LU I thought I'd see the o-ring that, according to the SELOC manual, I should be removing and discarding. It was not there on top of the drive shaft. When I peeped up through the drive shaft housing I could see what looks to be the o-ring up in the hole, BUT there is also some piece of metal something that is also hanging through the drive shaft hole. This worries me a bit. Any ideas what that might be? I'll attach photos. Also, please read on...
2. Upon removal of the waterpump housing I found what was left of the impeller. Almost laughable really (see photo). However, see that little piece of metal there next to the non finned impeller? that was found in there too. I don't know what it is but I'm sure it's not supposed to be there. I also don't know where it's from and that's a bit worrisome. How worried or not should I be to find that there?
