Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1980 15hp power head rebuild questions
  • 1980 15hp power head rebuild questions
    I am about ready to split the cylinder case to get to the crankshaft and ultimately replace a piston and rings due to a sieze. I do not want to replace items that are still good but am not sure what to look for.Specifically how do I determine if the bearings are good or bad. Can I make that determination now before I go in by checking for slop in the crank or am I looking for discoloration? Are there any parts that should be replaced as a matter of maintenance since I am in the case anyway? Any advice would be helpfull as I am entering uncharted territory.
    Re: 1980 15hp power head rebuild questions
    You really need a Repair Manual, BRC.You will need to dismantle and inspect the lower end to determine if the bearings need replacement.Good luck.
    sigpic
    • #3
      Hi BRC, Typically, bearings in need of replacement are OBVIOUSLY in need of replacement. Bearings that spin quietly, are shiny, and mate onto equally shiny journal surfaces are probably good. Bearings that have dark colored pits, rust, ridges, flat spots, etc. are probably bad. Race engine builders actually like using used bearings, as the motors run looser and faster... Also - get a manual - worth it's initial cost in saved frustration...- Scott
      Share A Project Page for 1971 GW Invader Banchie 13
      http://www.shareaproject.com/pages/p...,p,433,00.html
      Share A Project Page for 1976 American 18
      http://www.shareaproject.com/pages/p...,p,404,00.html
      Share A Project Page for 1974 American 15
      http://www.shareaproject.com/pages/p...,p,405,00.html
      • #4
        Thanks for both your input. I do have a manual and have been studying it thoroughly. It is a great help but tends to state things matter of factly with the assumption you know all the rest.This board has been a great place to fill in all the blanks.
        Back to Top
