Was running out for a quick fishing trip before work this week. Boat wouldn't start. Starter would turn but was not like normal. Sounded kind of labored. but after a few times it would start to crank like normal but didn't start. Put boat back up on the trailer and ran it home. Pulled all the plugs and inspected and sprayed some sea foam in each plug hole. Also sprayed seafoam in each carborator. I also re-seated a fuel line that appeared to be a little down on the connector. The engine started right up and ran it for 10-15 minutes. I waited a few hours and it started again.
Thinking I have fixed the issue, I went fishing on Saturday. Got down to the ramp similar issue as the other day.. Slow crank and after a few times was cranking like normal. Was able to get it started. Since it was cold out, I let it warm up for a good 15 - 20 min. Went out on the water and ran it to a few spots and ran it a 4-5k rpm for a good 20 minutes. Then moved it around to a few spots. started each time with out any issue. Ran again and while underway at about 27mph an 4k rpm engine cut out. I never got it started again. The Starter would crank but would not start. finally battery was worn down that i couldn't even crank at all. Had to be towed in. (OUCH)
Get it home and immediately put batteries on charger and get them up to 100%. I have two batteries about 2 years old. they are on a Marine switch that allows to isolate one or the other or use both.
Once they were fully charged, I went to attempt a start all i was getting a single CLICK then nothing. Thinking it was starter, I started to remove it for replacement. I decided it was worth replacing solenoid while i was doing it. Did that and either get nothing, a CLICK only or a partial crank then nothing.
Put a meter on Power feed side of Solenoid and it 12.4v. I don't get 12v on other side of the solenoid when key is turned to start. I get some low number like 4v and it is not steady. Similar results when on the POS post of the starter.
Since this is brand new Solenoid and similar issue to what I was having with old solenoid.
So I am thinking I should go load test both batteries, make sure the cables are cleaned up at contact points.
Any other thoughts of what could be causing the drop in the voltage to Zero?
