Bought the motor used for $225. The previous owner said it would not start so the first thing I do is clean the carb and replace all the rubber hoses. Update:
I unscrewed the forward nut of the primer and it came right off, then I removed the starter and then the carb. Cleaned the carb, reinstalled it.....everything good so far.
Now I need to "REWIND" the starter spring.
[FONT="]The only info I have states to move the pinion gear up to engage the flywheel and hold it with a wrench while rotating the flywheel “counterclockwise”. Is this correct? I tried to rotate it counterclockwise but it only rotated a couple of turns, however, when I tried to rotate the flywheel clockwise it rotated many turns. Did not want to complete this until I’m certain which way to turn it. Any thoughts?[/FONT]
