Damifudo
- Sep 14, 2009
- 277
I am pretty sure the power pack on my J150sledb 1996 is going bad. The engine randomly cuts off after its warm. It starts right back up and runs normal. I have checked the safety cutoff and the ignition switch but that does not see to make any difference. I have had it run a full day with no issues and then when I take it out a week later it will start acting up. I have checked the fuel system and found no issues there. What I read it sounds like a typical power pack going bad.
So my question is since I seem to have 3 choices. OEM, CDI and Seirra. All with in a few dollars of each other. Is there any difference in which one I choose? I guess you can never go wrong with OEM but before I choose I thought I would ask for advice.
Thanks for any reply's.
