Hi!
I got hands on an intake manifold and carb from an 35hp, the thing is that the carb comes with the choke system so i'm planning to go for it and convert to the choke system at the same time as i upgrade to 35hp.
But there is one difference, on the intake manifold there's a nipple that right now has a hose connected to it that goes to the primer pump, but the motor i took the parts from that hose went to another nipple on the bypass plate, to the left of the fuel pump.
On my engine that bypass plate doesn't have that nipple, where do you think i should connect the hose from the intake nipple, or could i just plug it?
Hope anyone can help, i post a pic showing the intake manifold nipple i'm writing about, this i how it looks right now, the 25hp carb.
Thanks, Patricio
Thanks, Patricio
