This is for a '64 Evinrude 18hp 18402D. The propeller shaft called for part number 313284, Sierra lower seal kit come with part number 311787 equivalent. There should not be a fitment issue with either of this part. One is ID .625, OD 1.125, Height 0.312 the other is ID .625, OD 1.128, Height 0.25.
So here is the problem I ran into, I pulled the seal on the gearcase head, cleaned and proceed to put the replacement seal and found out the it's too small. See attached pictures. I measured the ID of the gearcase head where the seal fit into and it's 1.25". Looking at all the dimension listed on Sierra website there is not one that have an outer diameter of 1.25" with an inner diameter of 0.625. The closet one would be 1.375" with 0.625 ID. I am not even sure if I should order this seal and try it out?
Anyone ran into this issue before, please help.
Thanks
Anthony
Thanks
Anthony
