1975 Johnson 85 HP (85ESL75)
I replaced the impeller but still had no water coming out the ports just below the outside cover when running on muffs. Took thermostat (vernatherm) assembly off and found some junk in there so I bought new vernatherm/thermostat. Before I put the thermostat assy back on I thought I'd submerge the foot in a drum of water and run it again. I was expecting to see water coming out the tubes near the bottom of the heads but I got nothing.
I am trying to get an idea first of the flow of water. Does it go from impeller, thru the water passages in the heads, out to the thermostat, and then out the exhaust ports? Will running it without the thermostat in there somehow cause the pump not to "prime"? I am at a loss to explain why I'm not getting water to the engine. This model h as two water tubes coming off the impeller housing. It's a PITA to get them lined up when putting the lower unit back on but I'm pretty sure they are. At least one of them is for sure. I assume one water tube goes to each side of the engine (one tube per two cylinders?).
Anyone who can shed some light on exactly how this works and what might be causing the problem would be appreciated.
Attaches a pic of the engine in its current state for whatever it's worth. I have labeled it A,B,C,D to show how I think the flow of water goes. Please correct me if I'm wrong.
