pulled the plugs and found very different conditions on plugs. gaps are the same but dont look like proper combustion. any ideas on where to start. carb has been rebuilt and compression is also not the same in the cylinders. 90psi and 140psi. do i have a rebuild project this winter? This is a 2000 4 stroke 9.9.
