Sirrobin53
- Mar 13, 2012
- 189
I am tuning an old 18 and have found that the PO had used resistor style wires and did not tighten the flywheel nut tight enough causing it to shatter the key. That in turn cracked the cam. Does anyone know which cams will work? Thanks in advance,
SR53
SR53
