Your thinking is correct. The larger carbs will flow more air and fuel, making more hp. The 10-15 hp increase is a good guess. It is likely the jetting on the larger carbs may overfuel somewhat..you'll have to run it and do some testing. You will be happy with the results when you are all done. Why not put the 140 heads on as well?
