Hi there,
So I had a problem with the spark on my bottom cylinder and thought it was coming from the power pack which I changed right away. I was still having issues so I inspected the stator wires and it turned out one of them was completely corroded and just crumbled when I touched it. Still, with the bad cable, the engine would fire on two top cylinders. I had a spare stator from another outboard that I had a tech put in. Now they are calling me saying that I don't have spark on any cylinder but the stator output is OK. They theory is that the timer base got somehow damaged. How could that be? CDI is new, and stator is good.
