My evinrude will bog down and die while moving unless you pull the primer a few times to shoot fuel into the carb. It doesn't idle very well either. Sometimes it'll run fine and most of the time it bogs and dies unless the primer gets pulled then it will pick back up and go for a short time then do it again. I've switched tanks, rebuilt the carb and fuel pump both and it still does it. Please help!!
