1957 evinrude big twin 35 low power
eolsen
I don't seem to have full power. Also I cannot lower the throttle to low speed it just dies. I have to stay in the throttle area from start to fast. Any input would be appreciated.....
Bosunsmate
check you have spark on both cylinders
Also do a drop test, (try seeing if its only one cylinder working by pulling each plug off the motor in turn, noting the difference, then replacing, sounds like its running on one cylinder
steelespike
I agree it could be on one cylinder.
Also there is a low speed and high speed mixture adjust needle valves.
Initial setting on Idle valve needs too be one turn out from gently bottomed,
High speed initial setting is 3/4 turn out from gently bottomed.
You may have to remove the knobs to do the initial settings.
Once the motor is warmed these need to be adjusted at the appropriate speed.
HighTrim
Step 1: Test Compression. That motor should be roughly 100 psi per cylinder, and even.
Step 2: Test spark: It should jump a 1/4" gap on an inline tester with a bright blue ZAP
Step 3: Ensure linc n sync is set, as well as carb settings as mentioned.
Things to note: If the coils are original, they are junk and need to be replaced. My guess is they are.
eolsen
It ended up being one if the cutoff switch wires heading to the magneto. It now runs on two cylinders!
