1967 evinrude 3hp compression
Have you heard this motor run ? -----Have you tested / calibrated the test guage ?------Many guages / techniques show different results.-----How long have you owned this motor ?
steelespike
I would say close to normal. Being even is is good. It warrants getting good spark and trying it with some 2 stroke starting fluid or a squirt of
outboard mix.
The motor runs great, starts first pull, idles good, I was just curious because most of my other outboards are in the 70 - 90 psi range. When I tested the 3hp and only got 50 psi, it made me wonder if that was too low.
boobie
If it runs good don't worry about it. You may want to do a decarb on it though.
