nphilbro
- Dec 19, 2011
- 304
I have the boat back home now and finally did some initial observation. Here are the issues I've dealt with much of the Summer/Fall.
1. Constant (solid) alarm condition
2. Intermittent failure to restart
3. No charging and no tach
I think (1) and (2) are related and might have narrowed the restart problem to a partially melted stbd side brown temp wire jacket. It appears the wire had pressed against the head at some point. It was an intermittent problem so hard to verify. The confusing part has been that the alarm would go on within a few minutes (or sooner) of starting the motor and remain on until d/c the alarm. The restart issue would never resolve itself until I removed the cowl - which would incidentally move the plug wires and temp wire. Does this motor have a fail safe to prevent restarting if it receives an overheat signal?
I'm well aware that a bad rectifier will kill the tach signal and charging but haven't done a diode test on it yet. My question is more specific to what impact having the wrong Spark Plugs and Plug Wires installed is to killing a R/R. I discovered that black copper conductor plug wires vs. the gray inductive wires and NGK BPZ8HS10 vs the recommended Champion QL78YC inductive plugs were installed prior to my ownership of the motor and didn't realize this until this week. Would that account for any of the 3 issues I'm dealing with? I'm not at all familiar with the operation of the Optical Sensor system but all the literature is quite explicit but haven't found any decent explanations. Of note: power pack and r/r units both appear to be replacements of original equipment (1997 Power Pack, 2007 rectifier).
The motor has been running great and estimate (by ear) that it's been getting up to at least 4k rpms, idles well...no noticable performance issues from that standpoint. I have two dedicated 700CCA starting batteries on a 1B2O Perko switch that I don't touch boat is back on the trailer. Batteries are well maintained with regular charging and usually start off reading between 12.7v and 12.8v at sunrise. Usually 12.3-12.4v when back home. I have two isolated SLA banks for the electronics and lights to prevent line induced RMI/RFI between the motor and each other.
