2Johnson50
- Sep 25, 2013
- 5
My 1972 50hp Johnson wont start with the engine cover on. If I remove the cover it will start and run but not very smoothly. The only thing I can think is that its running too rich with the restricted air intake with the cover on but get more air when its off. Does anybody have any ideas? My carb jets arent the standard tapered kind but are blunt on the end. I have been told that there is no carb adjustment but that doesnt make sense since the is access to the jets without removing the carbs. Are they talking about high speed adjustment or idle adjustment and not rich/lean adjustment? Any ideas would be appreciated. Thanks.
