I recently inherited an Evinrude Sportwin model 4423. I got it out on a lake and it had little power. I was told the carb needed cleaning. I tore it down as far as I could get it. (I did not remove the soft cover in back of the mixture screw area since I cannot find parts) Now, the bottom end of the float bowl has been a continual problem for me, Leaks fuel. Any suggestions on where to find parts, or how to ge tthis to seal would be great. Also, what would be good starting point settings for mixture screw would be appreciated.
