Found one! A very clean 1991 30 hp electric start tiller model.
In the process of installing it on my 14' Crestliner now. Operating range is up to 5800 RPM with the governor set at 6100 so it should be a fair bit faster than my 15.
The other day I was searching this Forum and came across a very detailed process to decarb with Sea Foam. Now I can't find it. Any help finding it would be appreciated.
Jim
Thanks Jasper. That is the one. My only concern is the method of burning the 1 gallon of mixed fuel with nearly a full can of Sea Foam. Should it be run on the water at full throttle with that mix or some other procedure. I don't want to mess up this nice engine.
