Lakeshadow
- May 29, 2012
- 205
What 'cha got to say about it? Got to change it to short shaft. Looks like the spark gets made under the flywheel. Showing a 9 amp stator plate under the generator, seen an exploded view. So there must not be a belt drive generator. Yet I see an amplifier...hummmmmm. New to me. Don't know if it's a heavy duty gear case or not. Won't know that till tomorrow. Points ignition yes! My old Aqua Meter tech should work fine with this. Miss Peachtree is capable of wringing out the mighty Ski-Twin with the adjustable pitch prop set at 13. Top end 29. Hoping a four cylinder cross fire will approach the 16 pitch limit of my prop? Also I want the old timer idle quality of putt-putting. Let's hear it!!! Scallywags.....ha..... Steady as she goes.... Steering to Liz's Lounge at the Riviera Resort.: http://youtu.be/sgBtlfqaQGo
