No matter whether I go full throttle or low speed, after some time I lose spark on the bottom cylinder. Turning off the motor and waiting doesn't do anything, unless I wait a very long time, but sometimes it just starts working again on its own while running. This problem is seemingly random, so it's not easy to reproduce to test and I have to do most of it on the water. I tried swapping the coils to no avail. Also replaced the power pack, no change. I unfortunately do not have a DVA, but there isn't much else that can fail. Some people say problems at high speed are usually stator. I have one from another motor that I could use to replace but have never pulled the flywheel and don't know how hard it is to do so and replace the stator. Are there any adjustements to do after you replace the stators/flywheel? Could the trigger be the problem? Ground wire maybe bad?
Thanks guys
Evinrude E70TLEOR 95' 3 cylinders 70HP
Thanks guys
