cerealdiet
- Apr 8, 2011
- 4
Just bought boat with this old motor (VXL-14B). Previous owner had run a tube from a fitting on bottom of block back to the fuel tank. Like a fuel recirculation system. Indeed, the fuel does return to the tank through this hose. I doubt it's supposed to, though. He has also cut and plugged a hose stub running from a similar fitting on same side of engine block that possibly originally ran to the fitting now plumbed back to the tank(?).
My questions: What does the fuel run look like for this engine? Should there be hoses that connect all these fittings in the block? I assume there should be a single fuel line running only FROM tank TO fuel pump.
Thanks.
Thanks.
