Help with a 5.5 hp Johnson CD-11 carb.
fishnferfun
I have newly acquired a 5.5 hp CD-11 and rebuilt the carb. After removing the carb from the intake I found a piece of foil covering the small hole on the carb and the block. I am enclosing pictures and wondered if the carb is correct or if something is missing etc. The person i got this from had never ran it. I am also considering putting a vacuum fuel pump on it and changing the twin hose fuel tank to a non-pressurized type. My first attempt at a boat motor. Any help would be greatly appreciated. A newibe fishnferfun PS; I am unable to upload pictures Great this is a waste,,,,, any suggestions?
fishnferfun
I really need to post pictures of this carb and where it bolts to so that you can see what i am talking about. I will try again. Well I just tried to upload a picture and I got a your file of 1770685 is larger than the 200000 allowed. My question is how can I get pictures to someone willing to help me? My email is REMOVED i know i can send them through email.
Don Hansen
If you're not familiar with 2 cycles that may be the reed valve. It's a one way valve that allows air/gas to pass into the crankcase but not back out thru the carb. It's best to not even touch it because it is easy to damage.
Tim Frank
Edit the picture for size....1.7 meg is big for posting to a forum.
nwcove
fishn.....is this ^^ what you are seeing behind where the carb bolts to the intake manifold? its the intake from a cd13 and normal.
fishnferfun
Thank-You all for answering me. I have run out of time to tell you what i want to, i need to get to church my wife is waiting. I will get back a little later fishnferfun
fishnferfun
No Title
OK i am now going to try and upload picts i have tried to resize the picts in picasa which i have never done before. Well i resized my pictures and I have been at this for 2.5 hours now. But now i think i know how to do this. Another Question i have is i have a Johnson 6 gal. boat gas can that has the 2 hose pressurized type and i am wondering if i should change this to a single hose type. it is in really good shape. Thank-You all very much for all your help, i am an old guy and this is intimidating for me to do this, especially since i type at 2 words a minute:) not really but close thank you thank you all
In your pictures the parts do not look like a CD-11 model at all.--Somebody has modified this motor !!!!!
HighTrim
That whole intake manifold, carb assembly in most definately NOT from a CD11, lol
I have to see more pics to see what has been done here!
Looks like a TECUMSEH engine has been transplanted to a JOHNSON.----Just a guess here.
HighTrim
I wonder why the previous owner would go to all that trouble? The proper carb is not all that rare. Not sure you would ever get that to run just right. Maybe though, never tried!
nwcove
yep....more pics are needed, from what can be seen, it doesnt even look like an omc powerhead?
fishnferfun
Wow, well that is a lot of information. It may be a few days but i will get more pictures after i do some disassemble y and then i can figure out what i should do.
I would like to thank all of you guys for the help. Blessings to all of you Richard
fishnferfun
No Title
Well I must say i am very impressed with you fellers knowledge!!! My life has been a mad house lately and I included the wrong pictures with the wrong motor. But i will give you all kudos, you figured out EXACTLY what i had. The pictures I included are from a Montgomery Ward Sea King 7.5 hp model CED-50577A. From what research i have done it is a 1981 eska Tecumseh 640-21. Today i disassembled the motor and i am going to need a gasket set and rings as the piston was lightly rusted and the rings were broke. I am going to include more pictures. I want to say again, Thank-You Guys so much for all your help. Richard
ps; are parts still available and where?
fishnferfun
I was hoping someone might know where i could get a gasket set and rings for my Tecumseh 7.5 hp motor. Thanks Richard
nwcove
you would have much better luck moving your question to the " other outboard brands" section of the forum, there are guys there that can steer you in the right direction. ( its a slow forum section...so be patient!)
Tim Frank
I am going to guess and figure that is an air-cooled engine since I am not aware of Tecumseh ever making anything water-cooled. Is it 2 or 4 stroke?
I'd be surprised if it is a purpose-designed unit and not just an off-the-shelf grab of an existing application....lawn mower etc.
Somewhere on the engine should be a more "complete" Tecumseh number.
Jack's Small Engines has the best existing availability of Tecumseh parts and they know their stuff. They should be able to help.
http://www.jackssmallengines.com/
fishnferfun
I am thankful to Tim and nwcove for your response. I will check out jacks and Tim the complete number is Model ced 50577a and serial 18X113147 Thank You Again
