jhallbuckeye216
- Oct 6, 2013
- 15
I bought the motor used on CL. I put it on the boat and went out twice over the weekend and once on Tuesday. When starting it up to return back to the ramp the starter wasn't spinning the flywheel. I gently moved the flywheel back and forth and it started. I didn't want to run it with whatever problem it was having so I got towed back in.
I got it to start again at home, and the flywheel moved free afterwards. Now the flywheel is locked up and metal pieces from under the flywheel are loose and hanging down between edge of the flywheel and the rectifier.
What could the problem be? The lower unit is free, propeller spins, and the motor was just spinning freely. In 24 hours of sitting it locked up.
