Greetings! My 1994 Evinrude 175 tilt quit. Only previous symptom of anything wrong was a little judder in the downward tilt in the high-speed range, happened for montths. Otherwise all great until she quit. The solenoids click and there is voltage going to the trim motor but not a peep from Mr. Motor. So the trim motor is shot, right? Well I pull it all apart and when put power to the (now free) motor, she spins! A miracle? I put her back together, she runs up for a few seconds, then sounds weak, runs down, sounds strong, rrrr...DEAD. Now its like it was before I started this miserable job. Is an intermittent electronic motor failure a likley event? I would have figured it would would either live or die. The trim motor is not that old - six/eight years - but gets a ton of use because i'm constantly in very shallow water (Chesapeake Bay) Dare I risk replacing the motor with an (expensive) new (nonreturnable) one? Or am I missing something critical that will make me slap myself in the head and be happy I asked the community? Thanks in advance - Mac in Annapolis
