glastronhp154
- Sep 3, 2014
- 9
i have a 1977 Johnson 115 that i recently had an ignition problem it would run fine for 15-20 minutes then it would not get up past 1500 rpms with out bogging or dying eventualy with the help of people on here i solved that problem with a new stator. now the boat will hole shot right up to cruising speed around 3500 and will try to open up but starts a high speed sounding sputter/almost sounds like its reving out but its not. it will very rarely go past 4000 rpms sometimes it will tho which is wierd and it will run up to 4600. the carbs have been cleaned 3 times now the coils have been replaced, the stator is new the plugs and wires are new , the fuel lines have been cleaned or replaced, the gas tank is new and fresh gas and seafoam are a standard for me. what do you guys think it could be drivvving meee nuuutss
