I have 'inherited' a 79 55hp Evinrude which had been sitting for about 5 years. This is the first time I have played with a boat motor, so my terminology may be off, and questions may sound dumb. Bear with me.
The heat alarm went off the first time I used it, so I replaced the impeller on the water pump. The impeller in there was badly melted. But there seems to be no paint discoloration around the head, so I am guessing that no one has ever run it too with coolant not working. Ran the boat, and water did come out the two slot at back of motor, but no small 'pee' stream, and eventually heat alarm went. I am guessing I should have replaced all the parts in the pump, as the metal cup was in pretty rough shape. So I have gone ahead and ordered a new pump kit (rather that just impeller).
I should mention that a fair bit of oil appeared in the barrel I was testing in, not sure if this is normal or not.
1. While I am waiting for the parts, I was wondering about the thermostat. Do I have to take the head off to get at the thermostat? I don't seem to see any sort of thermostat casing anywhere (externally).
2. Should I be able to blow air (with mouth) through the peel hole on back of cowl?
