Hi. Could use some help understanding what may be causing my 140 hp to have reduced power. Sometimes it runs fine, other times I can't get my 17.5' bow rider up on plane. I don't believe it's the gas (seen that before) and I've used multiple marine gas stations and run the boat almost to empty. It really seems to lose power under load -- like when I'm pulling a tube with kids on it, which makes no sense to me.... The engine never dies, just seems to lose most of it's power. It still rev's to around 4,500 rpm. I have replaced the plugs and the spark plug wires.
Temperature seems ok per the gauge. Fuel line pump ball seems ok, not really hard, but not collapsed.
I'm thinking fuel pump or ignition system, but each is about $500 to replace (parts) I think.
